BookmarkSubscribeRSS Feed
up1
Dec 4, 2015
cluster colors in JMP Multivariate platform
I am using the Multivariate platform to color the clusters. (Analyze -> Multivariate Methods-> Cluster
The cluster Dendrogram is not displayed as in clustered colors. Which option in the menu (maybe in the red triangle?) would color the clusters. Only 1 color means just 1 cluster but these are actually many clusters.
KarenC
Feb 10, 2013
Solution
Re: cluster colors in JMP Multivariate platform
You are correct, under the red triangle there is a "color clusters" option. You can select the number of clusters by a menu option or interactively on the Dendrogram (there is a diamond that you can grab and slide).
KarenC
Feb 10, 2013
Solution
up1
Dec 4, 2015
Thanks. That helped...(to be used with the "number of clusters" option)
