mattpace0
chart not launching under vba control, how to fix please?
VBA automation.  I notice charts do not launch until the script has finished.  I need to see them as the script is running, is there a way to fix this please?
Also, I assume related. The macro creates several charts.  But seemingly at random some of them fail to launch.  They appear in the Window list in the home window, but do not display until manually launched.  I assume i am doing something wrong, but don't know what it is.
Thank you for any assistance.
7 REPLIES 7
Re: chart not launching under vba control, how to fix please?
Hi Matt,
I apologize for somehow missing this when you posted it.  Can you provide the VBA source code that you are using?  Generally, if  you do a call sleep() in your code when there are timing issues, it can help with things like giving the analysis time to create a window.  The Analysis automation sample program that ships with JMP (c:\program files\sas\jmp\13\Samples\Automation\Visual Basic Samples\Analysis.NET)  provides an example of setting up the sleep call.  You must declare that you are calling an operating system function.  I'm using 13 as an example for the path, but this code shipped in the last 5 versions of JMP.
I hope that helps,
Brian Corcoran
JMP Development
mattpace0
Hi Brian,
I definitely appreciate your help.  I do not find any provision to attach anything.
If you use the "Advanced Editor", in the bottom left you will find an Attach icon.  Or, you can just pasteyour VB code to give me an idea what you are doing.
Brian
mattpace0
I can make it worse by adding more Sleep()'s.  This configuration typically fails to launch the first chart, but all subsequent will launch.
Sub GenChartsReview(Filter As Variant, _
                    Group As Variant, _
                    Iter1 As Variant, _
                    Iter2 As Variant, _
                    Iter3 As Variant, _
                    Stats As Variant, _
                    Iterate As Boolean)
    Dim APPjmp, TBLjmp, DOCjmp
    GetJMP APPjmp, TBLjmp, DOCjmp
    Dim Text As String
    Dim Success As Boolean
    Dim Stat, A, B, C, Index, PlotIndex, RowFilter()
    Dim VChart() As JMP.Variability
    If Iterate Then
        If IsReal(Iter1) Then ReDim VChart((UBound(Iter1, 2) + 1))
        If IsReal(Iter2) Then ReDim VChart(UBound(VChart) * (UBound(Iter2, 2) + 1))
    Else
        ReDim VChart(1)
    End If
    Index = 0
    For A = 0 To UBound(Iter1, 2)
        For B = 0 To UBound(Iter2, 2)
            Success = True
            Erase RowFilter()
            AddFilters RowFilter, Filter
            ClearRowStates TBLjmp
            If IsValid(RowFilter) Then Success = ExcludeGroup(RowFilter, TBLjmp)
            DoEvents
            If Iterate Then
                If IsReal(Iter1) Then IncludeItem Iter1(0, A), Iter1(1, A), TBLjmp
                DoEvents
                If IsReal(Iter2) Then IncludeItem Iter2(0, B), Iter2(1, B), TBLjmp
                DoEvents
            End If
            Set VChart(Index) = DOCjmp.CreateVariabilityChart
            If Success Then GenerateVarCharts VChart(Index), Stats, Group
            DoEvents
            Index = Index + 1
            Sleep 200
    Sleep 500
    If Success Then
        LaunchCharts VChart
    Else
        DialogAndLive "No Data To Plot, Are Filter Items Selected?"
    End If
    DoEvents
    Set APPjmp = Nothing
    Set TBLjmp = Nothing
    Set DOCjmp = Nothing
End Sub
Sub LaunchCharts(VChart() As JMP.Variability)
    Dim A
    For A = 0 To UBound(VChart) - 1
        VChart(A).Launch
        VChart(A).Visible = True
End Sub
This may be hard for me to replicate.  I would suggest trying a Sleep in the actual LaunchCharts subroutine after the visible call.  Setting the variables to Nothing at the end, while good practice, does mean that they can be closed down.
Brian
mattpace0
I may have found the problem, perhaps you could comment.
The code was generating an array of charts, then sending the array of charts to be launched and made visible
This proved to be unstable and be timing dependent.  i.e. - it would fail more often with larger data tables
Loop
     Generate Charts(Index)
Loop
     Charts(Index).Launch
     Charts(Index).Visable = True
I changed it to launching the chart at generation and sending the array of charts to be made visible.
So far, I have observed no abhorrent behavior
Loop
Loop
I think this is preferable. Any time you create the JMP instance in a subroutine and then null out the application pointer on exit there can be issues with automation. Creating the JMP instance and passing it in, making sure its lifetime persists for the length of your full operation, is usually the best approach.
In your case, the initialization of the underlying windows is probably the issue. It seems like your new approach gives them more time to be created, so when you make them visible the initialization is complete and a quick exit won’t hurt things.
Brian
