BookmarkSubscribeRSS Feed
lappelh
Not applicable
Aug 13, 2014
change the line color in parametric overlays from default settings
Often when I do Fit Life By X Nonparametric Overlays with parametric fits the default colors assigned to the fit lines are really bad (for example green and teal in the same plot, when there are only 4-5 different data sets plotted).  I would like to be able to change the line color to match the data point color (for example as assigned by using 'row colors' and then using a custom color scheme) or at least be able to change individual line colors so that they are not very similar.  Is there any way to do this?
XanGregg
Jun 23, 2011
Re: change the line color in parametric overlays from default settings
Changing the JMP preference for Categorical Color Theme should change those colors. You can pick from a few built-in sets or create your own custom set.
