a201lon
categorical responses in different situations
I wrote a simple script that work on my computer but when trying to run it
on other computer I get a window with a lot of plot options:
"categorical responses in different situations"
Do you know how i can disable it?
its stop the script before its runs.
the script:
New Column/*###*/("normal ACCESS X", set formula( ACCESS_X + 13 )
New Column/*###*/("normal ACCESS Y", set formula( ACCESS_Y + 13 )
New Column/*###*/("Field X", set formula( Modulo(normal ACCESS X, 2) )
New Column/*###*/("Field Y", set formula( Modulo(normal ACCESS Y, 3) )
New Column/*###*/("Filed number=(x+y*10)", set formula( Floor(normal ACCESS X / 2) + Floor(normal ACCESS Y / 3) * 14 )
New Column/*###*/("IO num", set formula( Num( Substr(IO, 2, 3 ) ) )
New Column/*###*/("Die Affected", set formula(
If(WithinFieldY > 17000,If(WithinFieldx > 7050,2,1) ,0)));
New Column/*###*/("Die Location", set formula(
If(WithinFieldY > 17000,If(WithinFieldx > 7050,"(1,2)","(0,2)") ,"DC")));
New Column/*###*/("Block", set formula(
If(Die Affected == 1 & (IO num == 159 | IO num == 223), 1,
If(Die Affected == 2 & (IO num == 191 | IO num == 255), 1, 0))));
New Column/*###*/("Block affected", set formula(
If(Block == 1 , "Affected","not Affected" )
Bivariate(
Y( :WithinFieldY ),
X( :WithinFieldX ),
  Dispatch( {}, "1", ScaleBox, {Add Ref Line( 7050, Solid, "Black" )} ),
  Dispatch(
   "2",
   ScaleBox,
   {Add Ref Line( 9000, Solid, "Black" ),
   Add Ref Line( 17000, Solid, "Black" )}
  Dispatch( {}, "Bivar Plot", FrameBox, {Frame Size( 622, 667 )} )
Chart( X( :IO num ), Y( N ), Bar Chart( 1 ), By( :Block affected ) );
Bivariate(
Y( :WithinWaferY ),
X( :WithinWaferX ),
SendToReport( Dispatch( {}, "Bivar Plot", FrameBox, {Frame Size( 545, 422 )} ) )
Chart(
X( :Name( "Filed number=(x+y*10)" ) ),
Y( N( :SSS_Bin ) ),
Bar Chart( 1 ),
thanks.
Alon
