dwalsh
back transformation in a Mixed model ANOVA
I apply a log transformation before an ANOVA - split-plot mixed model. The least squares means in the output correspond to a back-transformation = EXP(Y) wich is the median. The arithmetic mean is EXP(Y + variance/2). In a split-plot, there is more than one variance. Which variance should I use ?
Thanks.
