BookmarkSubscribeRSS Feed
tonyuow
Dec 20, 2011
automatic formulas
let's say I have 5 columns: A, B, C, D and E. I want to automatically generate new columns where each first four columns are divided by the fifth one, i.e. new columns are: A/E, B/E, C/E and D/E. Is there any way to do that automatically in JMP?
thanks
ms
Jun 23, 2011
automatic formulas
With JSL, yes. It pays off to learn JSL if plan to use JMP a lot.
For your specific example it be done like this:
For( i = 1, i <= 4, i++,
  Current Data Table() << New Column( Column( i ) << get name || "/E",
                    values( (Column( i ) << getas matrix) :/ (Column( 5 ) << get as matrix) )
Paste the code in a new script window, make sure your target  table is the frontmost data table and hit run.
XanGregg
Jun 23, 2011
automatic formulas
The way to do this without scripting is the "Substitute Column Reference" feature in Cols > Standardize Attributes. There's an example in the doc for making 9 new columns that is each the log of a previous column.
ms
Jun 23, 2011
automatic formulas
I never noticed the checkbox "Substitude Column Reference" before. Smart feature. Thanks!
