BookmarkSubscribeRSS Feed
assigning column modeling type
I'm new to the world of JMP and trying to teach myself scripting by creating some simple but useful scripts. I am currently trying to automate the process of changing the column types in a sheet to match those in a reference file. I know that the easy way to do this is to recreate the table and correctly import it or to change the formats by hand - but where is the fun / value in that?
I have a simple script that will read the modeling format of the columns in the 2 tables and tell me when they are different (and how they differ) but I'm failing at the point of actually comparing the format against a specifically defined type (e.g. "Continuous") or resetting the column formats. I am reading the current modeling type into a variable and trying to reassign this variable to a different column... but failing. I assume it's a simple format issue and that someone out there knows an easy answer :-)
mpb
Jun 23, 2011
Re: assigning column modeling type
This example doesn't do exactly what you want, but should point the way:
//Example toggles modeling type for a column and assigns it to another
column;
dt = open("$SAMPLE_DATA/fitness.jmp");
col1 = Column( dt, "Weight" );
modtype = col1 << get modeling type;
Show( col1, modtype );
col2 = Column( dt, "Oxy");
If( modtype == "Continuous",
    col1 << set modeling type(
"Nominal" ),
"Continuous" )
col2 << set modeling type(eval(modtype));
Show( col1, col2, modtype );
Message was edited by: mpb
Thanks for that - I've almost got it working... but not quite!
The code I have so far is :
/* COMPARE THE column types OF TWO DATA TABLES */
/* NB: Assumes columns are in the same order and have the same name */
caption("Please locate the reference data table.");
dt1=open("reference_table.jmp");
caption(remove);
caption("Please locate the data table to be corrected.");
dt2=open("table2fix.jmp");
caption(remove);
nc = min(ncol(dt1),ncol(dt2));
// Check for differing column types.
for(j=1,j<=nc,j++,
current data table(dt1);
n1=ColumnName(j);
t1=Column(j) << get data type;
m1=Column(j) << get modeling type;
colln1 = column(dt1, j );
current data table(dt2);
n2=ColumnName(j);
t2=Column(j) << get data type;
m2=Column(j) << get modeling type;
if(and(n1==n2,t1!=t2,m1!=m2),
write("\!rDiffering column types in column "||char(j));
if( m1 == "Continuous", print("Continuous found");
write("\!rColumn name=",n1,"| data type 1 =",t1," | modeling type 1 = ",m1);
write("\!rColumn name=",n1,"| data type 2 =",t2," | modeling type 2 = ",m2);
colln1 << set data type(eval(t1)) ; //Doesn't actually do anything
colln1 << set modeling type((m1)) ;
/* Column("R") << data type( numeric ) << modeling type( continuous ); //This row works */
show("M1 = "||m1);
); //end of if
); // end of for
It almost works. All of the variables display correctly and it compiles, and steps through the loop perfectly but... it has no effect on the actual column type in the sheet! Where have I gone wrong?
mpb
Jun 23, 2011
I think I have properly reconstructed your code though I have commented out the 2 write statements that caused syntax errors I didn't have time to track down.
If this indeed represents what you coded, then it looks to me as if you are setting the column in table 1 to have data and modeling types you got from the same table whereas I assume you mean to change the column in table 2. See if that makes a difference. You need an appropriately placed line: colln2 = Column( dt2, j ); and then send your messages to colln2.
style="font-size: 10pt; font-family: "Courier New"; color: green;">/*
TWO DATA TABLES */
style="font-size: 10pt; font-family: "Courier New"; color: black;">
same order and have
style="font-size: 10pt; font-family: "Courier New"; color: green;">the
same name */
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Caption
style="font-size: 10pt; font-family: "Courier New"; color: black;">(
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Please
style="font-size: 10pt; font-family: "Courier New"; color: navy;">;
style="font-size: 10pt; font-family: "Courier New"; color: black;">dt1
style="font-size: 10pt; font-family: "Courier New"; color: navy;">=
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Open
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"reference_table.jmp"
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">remove
style="font-size: 10pt; font-family: "Courier New"; color: black;">dt2
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"table2fix.jmp"
style="font-size: 10pt; font-family: "Courier New"; color: black;">nc
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Min
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">N
Col
dt1 )
style="font-size: 10pt; font-family: "Courier New"; color: navy;">,
Col
dt2 )
style="font-size: 10pt; font-family: "Courier New"; color: green;">//
types.
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">For
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">j
style="font-size: 10pt; font-family: "Courier New"; color: teal;">1
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><=
nc
style="font-size: 10pt; font-family: "Courier New"; color: navy;">++,
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Current
Data
Table
dt1 )
style="">
n1
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Column
Name
style="">
t1
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><<
get data type
style="">
m1
get modeling
type
style="">
colln1
dt1
style="">
Data
Table
dt2 )
style="">
n2
Name
style="">
t2
get data type
style="">
m2
get modeling
type
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">If
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">And
n1
style="font-size: 10pt; font-family: "Courier New"; color: navy;">==
n2
t1
style="font-size: 10pt; font-family: "Courier New"; color: navy;">!=
t2
m1
m2 )
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Write
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"\!rDiffering
style="font-size: 10pt; font-family: "Courier New"; color: navy;">||
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Char
style="">
Data
Table
dt2 )
style="">
m1
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Continuous"
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Print
found"
style="">
style="font-size: 10pt; font-family: "Courier New"; color: green;">//write("\!rColumn
name=",n1,"| data type 1 =",t1,"1," | modeling type 1
= ",m1);
style="">
name=",n1,"| data type 2 =",t2,"2," | modeling type 2
= ",m2);
style="">
Data
Table
dt2 )
style="">
colln1
set data type(
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Eval
t1 )
style="font-size: 10pt; font-family: "Courier New"; color: green;">//Doesn't
style="">
colln1
set modeling
type(
(m1)
style="">
Column("R") <<
style="">
style="">
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Show
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"M1
m1 )
style="">
style="">
style="font-size: 10pt; font-family: "Courier New"; color: green;">//end
of if
style="">
style="font-size: 10pt; font-family: "Courier New"; color: black;">)
style="">
end of for
for(j=1,j<=nc,j++,
n1=ColumnName(j);
n2=ColumnName(j);
show("M1 = "||m1);
); //end of if
); // end of for
