BookmarkSubscribeRSS Feed
cheryl_richards
Not applicable
May 27, 2015
are there some specific settings or versions of IE required to use interactive HTML?
are there some specific settings or versions of IE required to use interactive HTML?  I saved a distribution as Interactive HTML and when I open it, I see only the JMP logog anda "?".  We are using version 8 of IE
danielvalente
Jul 26, 2013
Solution
Re: are there some specific settings or versions of IE required to use interactive HTML?
Hello -- thanks for your interest in the interactive HTML report feature of JMP. The browser requirements are found here: Exploring Data on the Web. For Internet Explorer, version 10 at a minimum is required. Earlier versions do not perform as well and do not support all features.
Check out the JMP blog: jmp.com/blog
danielvalente
Jul 26, 2013
Solution
