BookmarkSubscribeRSS Feed
alter width of texteditbox (JSL)
I have been unsuccessful in being able to adjust the width of a texteditbox from the default of 4 characters. Does anyone know how or if this can be accomplished?
Re: alter width of texteditbox (JSL)
This is how I'd do it:
That is, cheat by inserting a long prompt above it, and force the two boxes to be aligned.
[NB: I've just discovered that this works in JMP 8.0.2, but not in JMP 7]
I use the same cheat as David suggested. You can use spaces as the prompt to make it invisible. I also reduce the font size to 3 or 4 so that it has minimal impact on vertical alignment ... this does mean however that you need a very long prompt!
Pity there is not a more elegant way. I keep meaning to write a function to generate the text box based on pixel width - it would then determine how many spaces need to be used to create a prompt of the correct size - still on my to-do list though
aim
Jun 23, 2011
Here is an alternative solution, which works in JMP7 too: use set wrap( ) option and keep Text Edit Box content long (backfill with extra spaces).
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">New
Window
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">(
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"test"
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">,
style="mso-tab-count: 1">
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Border
Box
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Left
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">5
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Right
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> top(
bottom(
style="mso-tab-count: 2">
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">V List
Box
style="mso-tab-count: 3">
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Text
Box
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Short
empty:"
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Text Edit
Box
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">""
Box
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Short:"
Box
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"short"
Box
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Long:"
Box
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"long
style="mso-spacerun: yes">
Box
empty:"
Box
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Repeat
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">100
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> )
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//<--long
empty
Box
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Persistent
width:"
pw_tb
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">=
Box
style="mso-tab-count: 4">
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'"><<
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">set
wrap(
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">200
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">Set
Script(
style="mso-tab-count: 5">
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Local
{tmp}
style="mso-tab-count: 6">
tmp
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> pw_tb
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> Get
Text()
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">;
pw_tb
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> Set
Text(
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Trim
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">tmp)
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">||
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">)
tsl
Jun 23, 2011
Perhaps a simpler solution is to use the << set width() option, provided you have JMP 9, this doesn't seem to do anything in JMP 8.0.2
New Window("Test",
V List Box(
"Test",
teb = text edit box("Change Me",
<< script(mytext = teb << Get Text),
<< set width(250)
"this doesn't seem to do anything in JMP 8.0.2"
... hence this thread
