BookmarkSubscribeRSS Feed
hardner
Nov 13, 2012
add graphics script on top of points?
If I draw on a graph using Add Graphics Script() is there a way to force that to be on top of the data points rather than behind?  Or, equivalently, to make the points move back?  Giving the points some transparency is somewhat helping me but I'd still like to be able to draw on top of them.
ian_jmp
Jun 23, 2011
Solution
Re: add graphics script on top of points?
Note the '3' and the '5' in the graphics scripts below. You can see which scripts are tied to the graphics box by right-clicking on it and selecting 'Customize...'.
NamesDefaultToHere(1);
// Some data
dt = NewTable("Point Cloud",
  NewColumn("X", Numeric, Continuous, Formula(RandomNormal())),
  NewColumn("Y", Numeric, Continuous, Formula(RandomNormal())),
  AddRows(10000)
// Bivariate with two graphics scripts
biv = dt << Bivariate(
  Y( :Y ),
  X( :X ),
  Dispatch(
  "Bivar Plot",
  FrameBox,
  {Frame Size( 497, 377 ),
  3,
  Description( "Behind Points" ),
  Pen Color( "Red" );
  H Line( 0 );
  ), Add Graphics Script(
  5,
  Description( "In front of Points" ),
  Pen Color( "Green" );
  V Line( 0 );
ian_jmp
Jun 23, 2011
Solution
// Some data
  AddRows(10000)
  Y( :Y ),
  X( :X ),
  Dispatch(
  "Bivar Plot",
  FrameBox,
  3,
  Pen Color( "Red" );
  H Line( 0 );
  5,
  V Line( 0 );
hardner
Nov 13, 2012
Thanks!  That did it.
