BookmarkSubscribeRSS Feed
waltp
accessing another table for Col Mean
I wrote a small script in which I create a table referenced by dtSum. This table has only one row.  I want to add columns and populate them with the means of columns of another table which is referenced by dt.  The question is how do I reference the columns of the other table, dt?  The script right now looks like:
for(i = 2, i <= 9, i++,
     dtSum << New Column( "att" || Char( i ),
                    Numeric,
                    Continuous,
                    << Set Each Value( Col Mean( dt:Column(  i - 1 )  ) )
This doesn't work.  How do I reference column i - 1 in table dt and then find its mean?  I wan to use Col Mean since I'll have to do this for other column stats.  Any suggestions are appreciated.
Thanks,
Walt
Re: accessing another table for Col Mean
The Column function allows an optional data table argument.  Instead of the dt:Column syntax, try this in your Col Mean function:
    Column( dt, i-1 )
Hope that helps!
Wendy
