qspringleaf
about JSL formula to mark lowest 6 numbers within each fixed Item
I have one table with column "ITEM" and "ID", and the "ID" column value is random, could help to suggest how to use JSL formula to create one new column, and fill in content "Y" when the "ID" value is the lowest 6 within each fixed "ITEM" value. thanks a lot
ITEMID6 low ID within each Fixed Item?
OHO112973Y
OHO1129111
OHO112972Y
OHO112971Y
OHO1129114
OHO1129113
OHO112969Y
OHO1129109
OHO112970Y
OHO1129116
OHO1129115
OHO1129110
OHO112974
OHO112968Y
OHO1129112
OHO1181126
OHO1181129
OHO1181130
OHO1181128
OHO1181127
OHO1181126
OHO118193Y
OHO1181129
OHO118192Y
OHO118196Y
OHO118191Y
OHO1181100
OHO118199
OHO118197
OHO118194Y
OHO1181128
OHO1181127
OHO118198
OHO118195Y
OHO119179
OHO119177
OHO119178
OHO119182
OHO119183
OHO119184
OHO119181
OHO119176
OHO119180
OHO119137
OHO119136
OHO119135
OHO119134Y
OHO119133Y
OHO119131Y
OHO119130Y
OHO119129Y
OHO119132Y
OHO119176
OHO119175
OHO1192161
OHO1192157
OHO119271Y
OHO1192153
OHO119268Y
OHO1192156
OHO1192155
OHO119273
OHO119267Y
OHO1192160
OHO119272Y
OHO1192158
OHO119269Y
OHO119274
OHO1192159
OHO1192151
OHO119270Y
Re: about JSL formula to mark lowest 6 numbers within each fixed Item
Here is one way to solve your issue.
Here is the formula I used
If( Row() == 1 | Lag( :ITEM ) != :ITEM,
	currentItem = :ITEM;
	theRows = Current Data Table() << get rows where( :ITEM == currentItem );
	For( i = 1, i <= N Rows( theRows ), i++,
		theRows[i] = :ID[theRows[i]]
	r = Rank( theRows );
	theValues = theRows[r];
	Remove From( theValues, 7, 9999999 );
If( N Rows( Loc( theValues, :ID ) ) > 0,
	"Y",
I have attached the sample data table shown above
You can also use Col Rank combined with if:
tempRank = Col Rank(:ID, :ITEM);
If(tempRank <= 6, "Y", "");
	"Y",
Better answer
Very nice, I was only barely aware of the 2nd argument, ByVar, to the Col functions. ColMax has it too, so the top 6 can be selected. (The by groups have different number of rows, a constant won't work.) max and rank and flipped are column names; the formula's column name is in the window title. The column name is used in subsequent formulas.
The formulas could be collapsed into one column; add parenthesis as needed. Expanded like this is easier to understand.The formulas could be collapsed into one column; add parenthesis as needed. Expanded like this is easier to understand.
ColRank has a rule for ranking duplicates; if you care about duplicates on the edge of top or bottom 6, check it out. In the 2nd by group, the ID 127 kept row 32 but not row 20 because of the flip. Without the flip, the rank would keep the earlier row.
