Evan_Morris
Zero-truncated poisson
Working on a series of distributions that are positively truncated, meaning that you can't have a zero value.   I'm 99% certain I can solve this normally with the distribution platform by simply offsetting the base data by 1, but I was curious if there was another way to do a zero-truncated poisson in JMP.
Same question for some of the exponential family of continuous distributions now that I think of it.  I know the Weibull has the threshold option, and I swear I've seen a threshold output on the Gamma, but it doesn't look like an option for the actual fit..  Is my best bet to solve the truncation to simply offset the data?
Article Labels
