Ted
Ted
Y Axis Format (2)
Thank You for this: https://community.jmp.com/t5/Discussions/Y-Axis-Format/m-p/214121#M42807
And how to COMPLETELY(!) erase numbers from the Y-axis?
Multiplying by 0 (Custom => value * 0) does not help (see picture).
I don't need a label on the Y-axis at all!
ian_jmp
Re: Y Axis Format (2)
Once you have interactively built the graph you want, double click on an axis. The resulting dialog should allow you to get things as you want. For example (and using Graph Builder), these settings:
give this:
If you want to get rid of the text that says "height" too, just click on it, press backspace and then return.
You can completly delete the axis:
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
biv = Bivariate( Y( :height ), X( :weight ) );
report(biv)[AxisBox(1)]<<delete;
Ted
Ted
Sorry, but I do not understand, because I do not know the script language
ian_jmp
give this:
Ted
Ted
Thank you!
