antonio-domenic
XML parsing: stop the parsing before complete it
I would like to know if it is possible to stop parsing using Parse XML function when a condition is found to save execution time. Thanks a lot in advance
Craige_Hales
Staff (Retired)
Re: XMP parsing: stop the parsing before complete it
maybe
 throw("found something")
in the handler. If that works (I think it should) you can wrap the calling code with
try( ... , show(exception_msg) );
and check exception_msg=="found something" and decide what to do.
(Also check out the XML import if you are loading something into a data table.)
Craige
Craige_Hales
Staff (Retired)
maybe
Craige
antonio-domenic
It works, thanks
