adjo9835
Would you implement any blocks of this script differently?
Hello.  I am new to jsl and have a feeling I am doing alot of things the long and hard way and that there may be built in functions which perform the same actions as my code.  The code I've written takes 2 data tables and converts them into 1 .mdf file  If you know of a simpler and/or more robust way of implementing any of the sections of code below, please clue me in! Sample data has been uploaded to this page.  Thank you.
//	AUTHOR: Adam Jones			DATE:	7 July 2019
//	Edits:	15 July 2019, Adam Jones. Removed IdVd data from output.
//			16 July 2019, Adam Jones. Added functionality of allowing user to leave data windows on screen after script is finished or to clear all windows after script has finished
//									  Added ability to handle input files containing differnt processes or device numbers.  Script saves output files as normal, but shows error window, leaving user to verify validity of output data
//			xx July 2019, Adam Jones. Added functionality of allowing user to set lambda for each capacitor and/or iv spline.
//	DESCRIPTION:	Converts CV and IV data from 2 independent .jmp or .csv files into 1 .mdf file, for use in ADS/AWR.
//	INPUTS:	CV data (.jmp or .csv, must contain columns: serial_num, v_dut_volt, c_type, process, reticle )
//		IV data	(.jmp or .csv, must contain columns: serial_num, vg_volt, , process, reticle )
//		Directory for output data
//	OUTPUTS:	3 .mdf files, containing CV, IV and CV+IV data, seperated into blocks, based on curve (Cdg-V, Cgg-V, Cds-V, Id-Vg), process and device number
//			1 .csv file, for use by an ADS batch simulatior (CSV_list Sweep Module)
//			WARNING: Output will overide any files in the output directory with the same name
//	FAIL CASES: 	1) Input file does not contain correct column names
//			2) Cell of columns named "process", "c_type", "sn", or "device_num" has been left blank
//			3) File contains IdVd data as well as IdVg data
//			4) Both input files contain different processes, sn's, device numbers
//			5) Incorrect user input
//	User input
DataIVname = Pick File(	// Prompt user to choose a file and return a string of the filepath
	"Select DCIV Data", // prompt message
	"", // initial directory
	{"All Files|*", "Excel Files|csv", "JMP Files|jmp;jsl;jrn"}, // file filter list
	1, // intially selected item
	0, // doesn’t prompt the user to save the file
	"" // file that is selected by default
DataCV = Open(	// Open file and assign it to variable
		"Select CV Data", // prompt message
prefilepath = Munger( Pick Directory( "Select Output Directory" ), 1, "/", "" );	// Prompt user to chose folder for data storage. Assign it to variable
filepath = Convert File Path( prefilepath, Windows );	// Convert prefilepath variable into a string, containing the filepath, in windows format
New Window( "Would you like to visually inspect data and lines of best fit for garbage or corruption?",
	<< modal,
	Text Box ("Would you like to visually inspect data and lines of best fit for garbage or corruption?"),
	Button Box( "Yes" , inspect = 0 ),
	Button Box( "No" , inspect = 1 )
//	Generate and save CV splines (curves of best fit) by combinations of :c_type and :process
Summarize( DataCV, processArrayCV = By( :process ) );	// Create array of manufacturing processes
Summarize( DataCV, deviceNumArrayCV = By( :device_num ) );
Summarize( DataCV, ctypeArray = By( :c_type ) );	// Create array of capacitance types
For( n = 1, n <= Length( ctypeArray ), n++, 	// Loop through ctypeArray
	For( o = 1, o <= Length( deviceNumArrayCV ), o++, 	// Loop through deviceNumArrayCV
		For( m = 1, m <= Length( processArrayCV ), m++, 	// Loop through processArrayCV
			temp = Substitute( 	// Return Expr(), after substitutions have taken place
					Expr(	// Define expression containing variables to be substituted
						biv = Bivariate(	// Generate line of best fit
							Y( :c_mm_deembed_pf ), 	// Set dependent variable
							X( :v_dut_volt ), 	// Set independent variable
							Where( :c_type == __ctype__ & :process == __process__ & :device_num == __deviceNum__ ), 	// Genearte lines based on 2D array: __ctype__ by __process__
							Fit Spline( /*__lambda__*/ 0.01, standardized, {save predicteds} )	// Define type of fit (spline), define lambda, save predicted values
				Expr( __process__ ), processArrayCV[m], 	// Substitute value of processArrayCV into Bivariate()
				Expr( __deviceNum__ ), deviceNumArrayCV[o],
				Expr( __ctype__ ), ctypeArray[n], 	// Substitute value of ctypeArray into Bivariate()
/*Expr( __lambda__ ), if(ctypeArray[n] == "Cgg",	// If ctype is Cgg, set lambda to 0.001, othwerwise set to 10.  lambda = 10 reduces noise but lambda <= 0.01 is needed to capture discontinuities in Cgg curves
										0.001, 0.1
			Eval( temp );
//	Create new CV table, containing only useful columns
CVdata = (Data Table( DataCV ) << Tabulate(
	Add Table(
		Column Table( Analysis Columns( :Spline Predictor for c_mm_deembed_pf Where, /*:Spline Predictor for c_mm_deembed_pf Where 2*/ ) ), 	// Dependent variable goes here. 1 to 1 relationship with leaves of categorical tree
		Row Table( Grouping Columns( :serial_num, :process, :device_num, :c_type, :v_dut_volt ) )	// Defines categorical tree, growing left to right, from :serial_num (trunk) to :v_dut_volt (leaves, independent variable)
)) << Make Into Data Table;
// Throw out redundant CV data
CVdata << AddRows( 1 );	// Add empty last row so while loop knows when it's reached the end
q = 0;	// End of data table flag
proc = "new";	// Check against every row of :process
dn = "new";
sn = 0;
i = 1;	// Row number
Print( "flag1" );
while( q == 0, 				// Delete redundant :process x :c_type combinations
	If( proc != :process[i] | dn != :device_num[i], // (1) If new process or device number has been detected, reset proc, sn and dn
		proc = :process[i];
		sn = :serial_num[i];
		dn = :device_num[i];
		i += 1;
	If( proc == :process[i] & sn == :serial_num[i] & dn == :device_num[i], 		// (2) Iterate through all rows of the new :process x :device_num combination
		i += 1
	If( proc == :process[i] & dn == :device_num[i] & sn != :serial_num[i], 		// (3) If new sn has been encountered, with the same process and device num, delete row.  Keep deleting until new process or device num has been detected (1)
		CVdata << DeleteRows( i )
	If( :process[i] == "", 		// (4) If end of table has been reached, exit loop
		q = 1
CVdata << Delete Rows( i );	// Delete empty last row
//	Add blocks, seperated by VARs, BEGINNINGs and ENDs, for use by ADS/AWR
Column( "v_dut_volt" ) << set name( "independent" );	// Change name of column "v_dut_volt" to "Independent"
Column( "independent" ) << data type( character );	// Change column type from numerical to character so that later on, VARs, used for ADS/AWR indexing, can be inserted into this column
Column( "Sum(Spline Predictor for c_mm_deembed_pf Where)" ) << set name( "spline" );	// change name of column "Sum(Spline Predictor for c_mm_deembed_pf Where)" to "Spline"
Column( "spline" ) << data type( character );		// Change column type from numerical to character so that later on, VARs, used for ADS/AWR indexing, can be inserted into this column
batchList = {};
j = 0;	// First block flag
cap = "new";	// Check against every row of :c_type
For( k = 1, k <= N Rows( CVdata ), k++, 	// Add VARs for ADS indexing
	If( cap != :c_type[k] & j == 1, 		// Enter this if loop every time except for first time, where "END" is not required
		CVdata << Add Rows( 4, k - 1 );	// Insert 6 new rows, above newly detected capacitor type
		cap = :c_type[k + 4]; 	// set variable to newly detected capacitor type
		proc = :process[k + 4]; 	// set variable to process of row containing new capacitor type
		dn = :device_num[k + 4];
		:independent[k] = "END";	// Mark end of a block
		:independent[k + 1] = "VAR Index(2) = " || Char( proc ) || "/" || Char( dn ) || "/" || Char( cap );	// Index of .mdf block, for use by ADS/AWR
		:independent[k + 2] = "BEGIN";	// Mark beginning of a block
		:independent[k + 3] = "% ind(1)"; // Lable first column as independent variable, for use by ADS/AWR
		:Spline[k + 3] = "dep(1)";	// Lable second column as dependent variable, for use by ADS/AWR
		k += 3	// Move k past newly created rows
	If( cap != :c_type[k] & j == 0, 	// Enter this if loop only once, at the beginning of the file, where "END"" is not required
		CVdata << Add Rows( 3, k - 1 ); // Insert 5 new rows, above newly detected capacitor type
		cap = :c_type[k + 3]; // Set variable to newld detected capacitor type
		proc = :process[k + 3];	// Set variable to process of newly detected capacitor
		dn = :device_num[k + 3];
		:independent[k] = "VAR Index(2) = " || Char( proc ) || "/" || Char( dn ) || "/" || Char( cap );	// Index of .mdf block, for use by ADS/AWR
		:independent[k + 1] = "BEGIN";	// Mark beginning of block
		:independent[k + 2] = "% ind(1)";	// Lable first column as independent variable, for use by ADS/AWR
		:Spline[k + 2] = "dep(1)";	// Lable second column as dependent variable, for use by ADS/AWR
		k += 2;	// Move k past newly created rows
		j = 1	// Set flag to 1, so END will be included at end of blocks
CVdata << add rows( {:independent = "END"} );	// Insert "END" at very end of file
//	Clean and save CV data table.  Clean windows
CVdata << delete columns( "c_type", "serial_num", "process", "device_num" );	// Delete all rows except for ind(1) and dep(1)
CVdata << Save As( Filepath || "CV_Output.csv" ); // Save as .csv file for concatenation to IV file
if(inspect == 1,
	Close All( Data Tables, NoSave )	// Close pop-up windows
// Generate and save IV splines (curves of best fit) by combinations of :process and :reticle_num
DataIV = Open( DataIVname );	// Open file containing IV data
Summarize( DataIV, processArrayIV = By( :process ) );	// Create array
Summarize( DataIV, deviceNumArrayIV = By( :device_num ) );
Print( "flag2" );
For( m = 1, m <= Length( processArrayIV ), m++, 		// Generates and saves all IdVg splines
	For( n = 1, n <= Length( deviceNumArrayIV ), n++,
		temp = Substitute(
				Expr(
					biv = Bivariate(
						Y( :id_amp ),
						X( :vg_volt ),
						Where( :process == __process__ & :device_num == __deviceNum__ & :iv_type == "idvg" ),
						Fit Spline( 0.001, standardized, {save predicteds} )
			Expr( __process__ ), processArrayIV[m],
			Expr( __deviceNum__ ), deviceNumArrayIV[n]
		Eval( temp );
//	Create new IV table, containing only useful columns
IVdata = (Data Table( DataIV ) << Tabulate(	// Create new table
	Add Table(
		Column Table( Analysis Columns( :Spline Predictor for id_amp Where ) ),
		Row Table( Grouping Columns( :serial_num, :process, :device_num, :vg_volt, :iv_type ) )
// Throw out redundant IV data
IVdata << AddRows( 1 );	// Add an empty last row so while loop knows when it's at the end
q = 0;
dn = "new";
proc = "new";
sn = 0;
i = 1;
Print( "flag4" );
while( q == 0, 			// Delete redundant splines (:process x :reticle_num combinations)
	If( proc != :process[i] | dn != :device_num[i] & :iv_type[i] == "idvg",
		proc = :process[i];
		i += 1;
	If( proc == :process[i] & dn == :device_num[i] & sn == :serial_num[i] & :iv_type[i] == "idvg",
		i += 1
	If( proc == :process[i] & dn == :device_num[i] & sn != :serial_num[i] | :iv_type[i] == "idvd",
		IVdata << DeleteRows( i )
	If( :device_num[i] == "",
		q = 1
IVdata << Delete Rows( i );	// Delete empty last row
Column( "vg_volt" ) << set name( "independent" );
Column( "Sum(Spline Predictor for id_amp Where)" ) << set name( "spline" );
j = 0;
dn = "new";
For( k = 1, k <= N Rows( IVdata ), k++, 	// Add VARs for ADS indexing
	If( dn != :device_num[k] & j == 1,
		IVdata << Add Rows( 4, k - 1 );
		:independent[k + 1] = "VAR Index(2) = " || Char( proc ) || "/" || Char( dn ) || "/IV";	// Index of .mdf block, for use by ADS/AWR
		k += 3;
	If( dn != :device_num[k] & j == 0,
		IVdata << Add Rows( 3, k - 1 );
		:independent[k] = "VAR Index(2) = " || Char( proc ) || "/" || Char( dn ) || "/IV";	// Index of .mdf block, for use by ADS/AWR
		k += 2;
		j = 1;
IVdata << add rows( {:independent = "END"} );
//	Clean and save IV data table
IVdata << delete columns( "device_num", "serial_num", "process", "iv_type" );	// Delete all rows except for ind(1) and dep(1)
IVdata << Save As( Filepath || "IV_Output.csv" );	// Save as .csv
if(inspect == 1,
// Concatinate IV and CV data
Fulltable = New Table( "Combined Data table" );	// Create new table
IVtable = Open( Filepath || "IV_Output.csv" );	// Open IV data
CVtable = Open( Filepath || "CV_Output.csv" );	// Open CV data
Fulltable << Concatenate( Data Table( IVtable ), append to first table );	// Concatenate IV data to empty table
Fulltable << Concatenate( Data Table( CVtable ), append to first table );	// Concatenate CV data to IV data
FullTable << delete columns( "Column 1" );	// Throw out garbage column
//	Save concatinated data table in .MDF format
xptPref = Get Preferences( Export Settings );
Preferences(
	ExportSettings(	// .mdf format
		End Of Line( CRLF ), 	// End of line marked by carrage return left field
		End Of Field( Tab ), 	// Tab delineated
		Export Table Headers( 0 )	// Do not include table headers
Fulltable << Save as( Filepath || "CV-IV_Output.mdf", "text" );	// Save combined IV and CV data as a .mdf file
//	Check that CV file contains exact same processes and device numbers as IV data
If( Length( processArrayCV ) != Length( processArrayIV ),
	New Window( "Error",
		<<Modal,
		Text Box( "IV and CV data contain differnt number of processes" ),
		Button Box( "OK" )
v = 0;
w = 0;
x = 0;
found = 0;
founds = {};
Show( processArrayCV );
Show( processArrayIV );
For( s = 1, s <= Length( processArrayCV ), s++,
	For( t = 1, t <= Length( processArrayIV ), t++,
		If( processArrayCV[s] == processArrayIV[t],
			found = 1;
			v++;
	If( found == 1,
		founds[s] = 1;
		w++,
		founds[s] = 0;
		x++;
	found = 0;
For( u = 1, u <= Length( founds ), u++,
	If( founds[u] == 0,
			<<Modal,
			Text Box( "IV data's processes do not match CV data's processes" ),
			Button Box( "OK" )
		Break()
If( Length( deviceNumArrayCV ) != Length( deviceNumArrayIV ),
		<<Modal,
		Text Box( "IV and CV data contain differnt number of device numbers" ),
		Button Box( "OK" )
v = 0;
w = 0;
x = 0;
found = 0;
founds = {};
Show( deviceNumArrayCV );
Show( deviceNumArrayIV );
For( s = 1, s <= Length( deviceNumArrayCV ), s++,
	For( t = 1, t <= Length( deviceNumArrayIV ), t++,
		If( deviceNumArrayCV[s] == deviceNumArrayIV[t],
			found = 1;
			v++;
	If( found == 1,
		founds[s] = 1;
		w++,
		founds[s] = 0;
		x++;
	found = 0;
	Show( founds[u] );
	If( founds[u] == 0,
			<<Modal,
			Text Box( "IV data's device numbers do not match CV data's device numbers" ),
			Button Box( "OK" )
		Break();
//	Generate Batch List File
batchList = {};
For( q = 1, q <= Length( processArrayCV ), q++,
	For( r = 1, r <= Length( deviceNumArrayCV ), r++,
		Insert Into( batchList, processArrayCV[q] || "/" || deviceNumArrayCV[r] )
For( s = 1, s <= Length( processArrayIV ), s++,
		Insert Into( batchList, processArrayIV[s] || "/" || deviceNumArrayIV[t] )
Insert Into( batchList, "XXX" );
Show( BatchList );
v = 0;
q = 1;
while( 1, 	// remove redundant values from the batch file
	v += 1;
	If( batchList[v] == "XXX",
		Break()
	while( 1,
		If( v == q, q += 1 );
		If( batchList[q] == "XXX",
			Break()
		If( batchList[v] == batchList[q],
			batchList = Remove( batchList, q ),
			q += 1
	y = 0;
	q = 1;
batchList = Remove( batchList, v );	// Remove XXX from end of batch list
batchTable = New Table( "Batch List" );
batchTable << New Column( "Index2" );
Column( "Index2" ) << Data Type( Character );
For( p = 1, p <= Length( batchList ), p++,
	Print( batchList[p] );
	BatchTable << Add Rows( {:Index2 = batchList[p]} );
BatchTable << Save as( Filepath || "BatchList.csv" );
//	Clean monitor
if(inspect == 1,
Craige_Hales
Staff (Retired)
Re: Would you implement any blocks of this script differently?
Looks like well commented code that won't be hard to maintain. I'm not really answering the question you asked because I don't see anything really wrong.
Superficial thoughts:
at the end might be a bit of a surprise to someone that had important modifications to an open data table. You can save the tables you open, perhaps in a list, and close just the ones you made.
When you set the prefs, you captured the original pref values but didn't use the captured value to restore them:
I think you can just eval the expression in xptPref after the save to do the restore.
If you have more than one table open, you should use a table variable with the column names; this might be a big help to a future maintainer:
	If( proc != dtA:process[i] | dn != dtA:device_num[i],
things get terribly confusing if the current table is used and more than one table has a process or device_num column. If you can use a better name than my dtA, that will help too.
The modal dialog for the inspect variable should handle the cancel case; if you "X" the dialog closed rather then Yes/No the inspect variable is undefined. You should set inspect to -1, perhaps, before the modal window. Also the 0/1 logic for inspect seems reversed for its name.
Thanks for sharing; I like the way you used the tab delimited/no header output of a "text" file to make the file you needed.
Craige
