With Button in application builder create a new datatable from what has been filtered with application
bjbreitling
Dec 13, 2012
I would like to create a new datatable from the sorted data of application builder.  Basically sort through the dataset to find what you want and then hit a button that generates a new datatable for another JMP application to work with.
Basically, load an application that allows you to use data filter to sort through data and then use a button to make a subset of what is highlighted.
1 REPLY
bjbreitling
Dec 13, 2012
