Thierry_S
Windows 10 Recent Files and Folders: Pointing to the "Quick Access" file and folder list in a JSL script?
Hi JMP Community,
Is it possible to point to the Window 10 "Quick Access" file and folder list in JSL script using such command as
Pick File ("PICK A FILE", <Quick Access Location>)?
If not possible, is it possible to point to the "Recent Files" list within JMP?
Thank you for your help.
TS
Thierry R. Sornasse
phil_kay
Re: Windows 10 Recent Files and Folders: Pointing to the "Quick Access" file and folder list in a JSL script?
I took this example from the JMP Scripting Index for Pick File():
Pick File(
	"Select JMP File",
	"$DOCUMENTS",
	{"JMP Files|jmp;jsl;jrn", "All Files|*"},
	1,
	0,
	"newJmpFile.jmp"
And I modified it for the location of my recent items:
Pick File(
	"Select JMP File",
	"C:\Users\xxxxxx\AppData\Roaming\Microsoft\Windows\Recent",
	1,
	0,
	"newJmpFile.jmp"
(where "xxxxxx" is the user ID of interest)
Works for me.
Phil
phil_kay
Pick File(
	"Select JMP File",
	"$DOCUMENTS",
	1,
	0,
	"newJmpFile.jmp"
Pick File(
	"Select JMP File",
	1,
	0,
	"newJmpFile.jmp"
Works for me.
Phil
