BookmarkSubscribeRSS Feed
sanqub
Jan 11, 2016
Why the time as data filter option doesnt work in Graph builder?
Dear community members,
I am trying to find a simple correlation of "time of day" and defect percentage. For this, I am using graph builder and time as data filter. Instead of using "ordinal data type" and a checkbox, I would prefer to have "time as continuous" as I can easily select any time range for instance 07.30.00 - 09.30.00
However, I find data filter doesn't work in this case. Do you think binning is only option in this case?
Thanks for your help.
David_Burnham
Jul 13, 2011
Re: Why the time as data filter option doesnt work in Graph builder?
I'd probaby start off by trying a semi-continuous scale by using the HOUR function to create an 'hour of day' column
-Dave
sanqub
Jan 11, 2016
Thanks, I have just tried that, quiet useful.
Jun 22, 2012
I don't know if this comment will be useful, however, I just changed the format for the Time of Day column, from h:m:s to Day:hr:m:s and it allowed the data filter to work without issue.
sanqub
Jan 11, 2016
Its brilliant trick, it works.
However, it changes the values. For instance Time: 16.39.43 has changed to 00.07.20.17.
