hockswender
Why suddenly JMP 7 now closes with Unable to write file Buffer Error?
The last update to jmp.pfs was 2/14/14. I don't know what event (if any) occurred with my system around that time. Since preferences not correctly written, the 'Tip of the Day' never changes. This doesn't matter to me, just mentioning the side-effect. Just worried about long term stability.
The path to the .pfs file seems correct in the File Location box under Preferences.
Any advice appreciated. Thanks. Tim
