BookmarkSubscribeRSS Feed
d_benetton
New Contributor
Jul 12, 2018
Why is the number of variables limited when using stepwise regression?
Hi everyone,
Disclaimer: I'm very new at using JMP so this could be a basic error. Even still, I'd appreciate help.
I've been trying to use stepwise regression fit model to see what effect single variables, two-factor variables, and quadratic variables have on the outcome variable. When I hit "enter all" after selecting backward direction, it will only add 13 variables, and I can't click on the checkboxes to add more. I want to be able to add all of the variables & interactions, but I can't add them. I think it has something to do with the degrees of freedom but I'm not sure. Grateful for any help.
cwillden
May 1, 2017
Solution
Re: Why is the number of variables limited when using stepwise regression?
How many rows of data do you have?  I would have guessed you are right that the constraint is you can't exceed number of rows you have in the number of starting model terms because you will have non full rank matrix and you won't be able to estimate all the parameters.  In that case, you would have to do forward selection.  However, it looks like you have 28 degrees of freedom for error even with all those boxes checked, so that doesn't seem like the case.
-- Cameron Willden
cwillden
May 1, 2017
Solution
-- Cameron Willden
d_benetton
New Contributor
Jul 12, 2018
I have 41 complete rows of data.
markbailey
Jun 23, 2011
How many observations do you have? Be sure to subtract number of excluded rows and rows with missing response?
d_benetton
New Contributor
Jul 12, 2018
I realized that I did not have enough data. Thanks for all the help, Mark
markbailey
Jun 23, 2011
Back to basics!
Is this an observational study or a design experiment?
What is the distribution of the predictors and the response?
You might have many observations (number of rows) but what information do they provide?
