lwx228
Why does JMP automatically exit or fail to respond when operating with a JSL batch decision tree?
Consult a professional:
Recently, I coded the code with JSL to carry out the multi-file batch decision tree operation, and each decision tree also performed the loop operation with different parameters and output each operation result.
Often MP will exit automatically or fail to respond.
The computer used little memory and CPU to observe the operation, and restarting the JMP was able to complete normally when the error file was continued to make the decision tree, but the same problem occurred after JSL recalculated for some time.
thank you!
lwx228
Re: Why does JMP automatically exit or fail to respond when operating with a JSL batch decision tree
Often JMP will exit automatically or fail to respond.
lwx228
I'm using the Windows 64-bit edition.
It's currently about 200 results and that's what happens.
Forms and Windows generated during the process are closed in time.
Close All(DataTables,"No Save");
I suggest you take this to the JMP support folks
     support@jmp.com
lwx228
thank Jim!
