BookmarkSubscribeRSS Feed
dstahlke
Sep 23, 2014
Why does Fit Model only work with current table?
I am new to jmp and jsl and unable to understand why the code below produces an error.
dt = open("simple.csv");
xyz = New Table("xyz", invisible);
//Current Data Table(dt);
fm = Fit Model(
        Y(dt:X),
        Effects(dt:Y),
        Personality(Standard Least Squares),
        Run Model,
        Invisible
Print(fm);
Close(xyz);
Close(dt);
This produces the following error:
Cannot run without Y Responses
Specified Column not found in data table.{1} in access or evaluation of 'List' , {dt:X}Column not Found{1} in access or evaluation of 'dt:Y' , dt:Y
In the following script, error marked by /*###*/
Fit Model(
     Method( "EMS", <<On ),
     Emphasis( "Effect Screening", <<On ),
     Keep dialog open( 1 ),
     Y( dt:X ),
     Effects( dt:Y ),
     Personality( Standard Least Squares ),
     Run Model,
     Invisible
Model Dialog[]
However, if I don't create the xyz table, or if I close it before doing Fit Model, or if I uncomment the Current Data Table(dt), then it works.  So it would seem that Fit Model can only operate on the current table.  Is this a bug in jmp or am I missing something?
michael_jmp
Jun 23, 2011
Solution
Re: Why does Fit Model only work with current table?
Platforms generally work on the current data table. However, you can make your script more robust by using the Send operator (<<) to explicitly state which table the platform call should apply to:
fm = dt << Fit Model(
        Y(dt:X),
        Effects(dt:Y),
        Run Model,
        Invisible
Michael Crotty
Sr Statistical Writer
JMP Development
michael_jmp
Jun 23, 2011
Solution
        Y(dt:X),
        Effects(dt:Y),
        Run Model,
        Invisible
Michael Crotty
JMP Development
dstahlke
Sep 23, 2014
Okay, thanks!  So, given that platforms operate only on the current table, is there any point to referring to the columns as "dt:X" rather than just ":X"?
michael_jmp
Jun 23, 2011
Not that I know of. I generally just use the ":X" reference in platform scripts.
Michael Crotty
JMP Development
