BookmarkSubscribe
Why did JMP rewrite my scripts??
I had scripts that, for example, had
t = concat(t, a);
And now I see JMP changed it to
::t = ::t || ::a;
It still works, but I don't understand the change, and too much work to find them all and change back :(
Re: Why did JMP rewrite my scripts??
Anybody have an idea?
Jeff_Perkinson
Where was this script stored, in a JSL file or a script property on a data table or somewhere else?
What did you do that caused JMP to change the script?
-Jeff
Stored on a data table.
I didn't do anything...but did work with JMP for a while and just saved the table...
Jeff_Perkinson
You must be using JMP 7 (or perhaps earlier).
When you store a script attached to a data table, JMP parses the script and stores a parsed version. This has a side affect of sometimes changing the script when it's redisplayed, especially when there are equivalent functions and operators.
JMP 8 does a better job of restoring your script just as entered.
-Jeff
No, it is JMP 8.
Jeff_Perkinson
Hmmm...that's interesting.
I'm able to reproduce the behavior in JMP 7 but not JMP 8.
-Jeff
Did you right click on the script screen the select reformat script? I have seen some strange reformats when I do this, but none that change my variable declaration to using doulbe semi-colon (::) . I use JMP 7 though.
