LBrian
Why can't create a histogram?
Hi everyone.
I wanna make a histogram using JSL.
1)
dt = Open( "$Sample_Data/Big Class.jmp" );
dt = Current Data Table();
Input = New Window( "example", << modal(),
	new1 = hlistbox(
		Text Box( "Test name :" ),
		Para_Num_teb = Text Edit Box( "", <<set width( 200 ) )
		text box("Click OK"),
		Button Box( "OK",
		Para_Num = Para_Num_teb << get text();
Histogram = Distribution(
	Continuous Distribution(
		column( column(dt, Para_Num )),
		Vertical( 0 ) ,
It can be run normally.
2)
	new1 = hlistbox(
		Button Box( "OK",
dtLimits = New Table("Option Table",
		Vertical( 0 ) ,
But, It can't be run.
I want to make a JSL for creating histogram using the 2nd script.
Could you give me any advice?
Re: Why can't create a histogram?
The issue you are having, is that when you added in the lines of code to create the limits table, JMP moved the Current Data Table from Big Class, to the Option Table.  Thus, when the Distribution fired up, it looked to the Option Table for the data.  The simple fix, is to point the Distribution Platform to the data table where the data are.  See below:
	new1 = hlistbox(
		Button Box( "OK",
Histogram = dt << Distribution(
		Vertical( 0 ) ,
The JMP report output is tied to the data table.  So when you close the data table, it has to close the report output.
There are things you can do to get around this.
  1. Copy the report output to a JMP Journal.
  2. Minimize the data table, don't close it.
  3. Use the Show Window() message to hide the data table.
	new1 = hlistbox(
		Button Box( "OK",
		Vertical( 0 ) ,
LBrian
Your solution which bring me new inspiration, is very simple and perfect everytime.
Thank you
LBrian
Hello, doctor.
Could I ask you one more?
I want to close windows except histogram
So I added 2 lines using close window().
	new1 = hlistbox(
		Button Box( "OK",
		Vertical( 0 ) ,
window("Option Table") << Close Window();
window(dt) << Close Window();
but this code closed all windows.
Could you give me advice more?
LBrian
Thanks to your advice, I can get a solution.
Thank you!
