Stokes
Why Expr() not working occasionally?
Hi, I am using Expr() function to quote a long jsl time to time, some time it works, some time it doesn't work.
For instance,
I set a VG plot as below,
VG= Expr(New Window( "Variability Chart",
V List Box(
Variability Chart(....)));
When I run
VG;
It is not working or responding.
Is there any rule of Expr() ?
gzmorgan0
Re: Why Expr() not working occasionally?
@Stokes ,
I expect you have syntax errors.
Note I like to make a reference to the expression (vgExpr) and create a handle/reference to the report (VG).
vgExpr = Expr( New Window("Variability Chart",
	   VListBox(
	   	  VG = Variability Chart(
			Y( :height, :weight ),
			X( :age, :sex )
		)//end Var Chart
	) //end VListBox
  )  //end new window
 ); //end Expr
 vgExpr;
 VG << 	Std Dev Chart( 0 );
 report(VG[1])[FrameBox(1)] << {Row Legend(
				sex,
				Color( 1 ),
				Color Theme( "JMP Default" ),
				Marker( 0 ),
				Marker Theme( "" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
 report(VG[2])[FrameBox(1)] << {Row Legend(
				sex,
				Color( 1 ),
				Marker( 0 ),
				Marker Theme( "" ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
gzmorgan0
@Stokes ,
	   VListBox(
			X( :age, :sex )
		)//end Var Chart
	) //end VListBox
  )  //end new window
 ); //end Expr
 vgExpr;
				sex,
				Color( 1 ),
				Marker( 0 ),
				Marker Theme( "" ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
				sex,
				Color( 1 ),
				Marker( 0 ),
				Marker Theme( "" ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
Stokes
THanks for the help.
Yes, it seems to be a syntax issue.
I compared your jsl and find below is the problem.
Is there a rule of sequence? Such that, the vgExpr = Expr(...) has to be run first, then the vgExpr will work.
I usually put the vgExpr = Expr(...) at the bottom of the jsl, then it will not work if I use the vgExpr before the definition part.
