joegliem
When using JMP Pro 13.2 with the Excel Addin for Excel 2016, I get "JMP-COM Error: Unable to launch"
When using JMP Pro 13.2 with the Excel Addin for Excel 2016, I get a "JMP-COM Error: Unable to launch JMP" when I try to run a model that was created.  Any help with this issue would be appreciated.
Thank you,
Re: Excel Addin
Hello.  This issue could be caused by a disconnect between JMP and Excel.  Let's try repairing that link.  Within JMP, click File -> Preferences -> Windows Specific and click "Reset Associations" at the bottom of the screen.
Now open the Excel file and try to transfer the data to JMP.
joegliem
Re: Excel Addin
I have attached my output from the Excel Addin Trial Run using the Demand.xls file included with JMP 13. I got JMP to run, but as you can see; it didn't give me any output. I show the Excel file in JMP and the output from the Run Command. Any help would be appreciated.
Thank you,
Joe
Jeff_Perkinson
Re: Excel Addin
There are no attachments in your reply immediately above.
Perhaps you replied by email. Unfortunately, email attachments don't make it through to the post. Instead, log in and attach them to your reply.
-Jeff
