lwx228
When the decision tree operation is completed, can JSL be used to save "save prediction formula"?
Hello, everyone!
I did step 1 first: manually click "GO" in the menu interface of the window and wait for the completion of decision tree operation.
I want to use JSL for the next step: how do code JSL to save the window menu operation to "save prediction formula" in the data table?Thank you very much!
p<<save prediction formula;
Re: When the decision tree operation is completed, can JSL be used to save "save prediction for
Here is the example from the Scripting Indix for the Partition Platform for Saving Prediction Formula
     Help==>Scripting Index...............Partition==>Save Predicion Formula
obj = Open( "$SAMPLE_DATA/Boston Housing.jmp" ) <<
Partition(
	Y( :mvalue ),
	X(
		:crim,
		:zn,
		:indus,
		:chas,
		:nox,
		:rooms,
		:age,
		:distance,
		:radial,
		:tax,
		:pt,
		:b,
		:lstat
	Split Best( 4 )
obj << Save Prediction Formula;
lwx228
Thank Jim!
This time, I have a special requirement that I do not want to use JSL to automatically make the decision tree, but only use JSL to copy the formula behind the decision tree.
Or another way of asking:
A table and a decision tree window are now opened. The name of the table is not necessarily Boston housing.jmp.
How do I get the names of these two files with JSL?Thank you very much!I will not use JSL to get another file name that is not the current interface.
gzmorgan0
This might be more generic than what I think you requested. Jim might have a better solution.  Note the syntax to get the scrciptable object in case you want to sen messages to the Partition object.  This assumes only one partition window  and gets the first one.
Names Default to Here(1);
rptList = Get WindowList("Reports");
//Assuming one partition
For(i=1, i<=nitems(rptList), i++,
    ttl = rptList[i] << get window title;
	If (contains(ttl, "- Partition of"),
	    treeref = rptList[i];
	    dtref = (treeref[Outline Box(1)] <<  get scriptable object) << get data table;
	    dtnme = dtref << get name;
	    varnme = Munger( ttl, 1, dtnme || " - Partition of ","");
	    Break();
show(ttl, dtnme, varnme, treeref<<get window title);
func = column(dtref, varnme || " Predictor") << get formula;
show(func);
lwx228
I seem to have mixed things up.I thought of another way.Thank you very much!
