BookmarkSubscribe
jump
Community Trekker
When creating tables from a array\list? How to order it in sequence from the list and not name
When creating tables from a array\list? How to order it in sequence from the list and not name.
for eg..  list1 = {idle,slow, fast};  or put same thing column.
when i create table(using TABULATE) based on this list or column it .. changes order to alphabetic. How do i prevent that?
btw, i tried putting number in front of the Name\character... it still does not work.
thx
Jeff_Perkinson
Re: When creating tables from a array\list? How to order it in sequence from the list and not name
You can use the Value Ordering column property to control the order values are shown in reports.
This property is scriptable with the Set Property() message to a column:
Column(dt, "speed")<<Set Property( "Value Ordering", {"idle", "slow", "fast"} )
-Jeff
-Jeff
Jeff_Perkinson
-Jeff
-Jeff
