BookmarkSubscribeRSS Feed
When I create an add-in the menu does not show up on JMP and the add-in does not show as enabled
johnmoore
Jun 19, 2014
I have made add-ins before and not had this problem.  Not sure what I am doing wrong.
markbailey
Jun 23, 2011
Are you using the Add-in Builder (File > New > Add-in) or the original manual process to create the add-in? Can you examine the contents to be sure that everything is included as you intended?
Eric_Hill
Oct 1, 2013
Also, if you could include screenshots of your add-in's contents, what the View > Add-Ins dialog looks like, those kinds of things, we might be better able to assist you.
Eric
