Hello Everyone,
I am working on a project that needs me to select modules based on users' input. And there are multiple parameters that I need to base on when select modules. The picture is showing below:
Could you please give me some suggestion about it? I am wondering if JMP has the function that I can use in this case.
Thank you so much if you can help.
Winnie
It's not clear to me what you are asking. But if you want to optimize your Y (module) based on multiple factors (parameters), that is what the Profiler is used for. My guess is your modules aren't a continuous variable though, so you'll probably have to script out the logic yourself with if... else statements
Thank you so much for your answer. Yes I am trying to find best modules based on multiple factors. I will do more study about profiler. It is very helpful!
