sunbears
What regression model is used by Line of Fit in Graph Builder?
I need to disclose in a report which regression model I used, e.g. least squares, Deming, Passing-Bablock. I achieved the regression with Line of Fit function in Graph Builder. Both X and Y are continuous variables. Two Qs:
  1. What is the default regression model used by the Line of Fit function in Graph Builder?
  2. Can the model be changed? (even if in JSL)
Jeff_Perkinson
Re: What regression model is used by Line of Fit in Graph Builder?
The Line of Fit in Graph Builder is a simple least squares model.
There are a few other methods (Polynomial, Robust Cauchy, and Time Series) available in Graph Builder.
The Method Comparison add-in supports Demming and Passing-Bablock regression.
-Jeff
Jeff_Perkinson
-Jeff
