BookmarkSubscribeRSS Feed
What new JMP 8 settings should I make?
I just installed JMp 8 recently. My problem is some settings seem different from JMP 7.X that I'm used to.
For example, with an opened data table in JMP 7.X, i generated a graph and both the data table and corresponding graph would stay open. However, with JMP 8, after I generated the graph from an opened data table, it seems that the data table is closed automatically and dissappears, and I have to open it everytime which seem strange.
Can someone give me some tips to rectify this? Thanks!
Re: What new JMP 8 settings should I make?
I have never had this happen to me. My table stays open when I create a graph. Are you on Windows or Apple. Have you contacted JMP support at support@jmp.com?
