Aziza
What is the function to deactivate Automatic Fontsize in Graph Builder?
Hi All,
I have a script which generates Graph Builder Reports and I want to deactivate the "Automatic Fontsize" option. Is there such a function?
Thank you!
Re: What is the function to deactivate Automatic Fontsize in Graph Builder?
I assume you are referring to the font size of axis labels - to set the option through the UI, double-click on the axis to find the option in the popup dialog:
If you save the script after applying the action, it will look like this:
Graph Builder(
	Size( 495, 464 ),
	Show Control Panel( 0 ),
	Variables( X( :State ) ),
	Elements( Points( X, Legend( 2 ) ) ),
		Dispatch( {}, "State", ScaleBox, {Label Row( Automatic Font Size( 0 ) )} )
Graph Builder(
	Size( 495, 464 ),
Thomas1
Level V
Can this be done by default within the preferences?
I don't believe there is a preference for the font size.
Aziza
Thank you a lot for helping me to figure it out! This is exactly what I meant! :)
