Thierry_S
What is the fastest way to reorder by name only a subset of columns in a large table (JMP 14.1)?
Hi JMP community,
What is the fastest way to reorder by name only a subset of columns from a large table (JMP 14.1)?
The Cols > Reorder Columns > Reorder by Name seems to only reorder all columns in the table and does not work with Grouped columns.
I have used the rather cumbersome approach of stacking the desired subset of columns and then split those again but I would expect JMP to have a more convenient way to perform this apparently somple task.
Thank you for your help.
TS
Thierry R. Sornasse
Re: What is the fastest way to reorder by name only a subset of columns in a large table (JMP 14.1)?
You will probably have to use a script to reorder only a specific list of columns by name.
