tim_ka1
What happened to combined windows option in JMP 12?
I used to be able to combine multiple report windows into 1 (using the "combine windows" checkbox located at the bottom right of the JMP window).  This was very useful for me to help summarize and visually show the analysis I was conducting.
can anyone help explain to me where is this option in JMP12?  Did they remove it and if so, did they replace it with a similar option?
Please help.
Thank you.
Tim
tim_ka1
Re: What happened to combined windows option in JMP 12?
Just found out that the "Combine selected windows" option can be enabled through the top dropdown menu...
Window-->Arrange-->.....
then choose "Select All for Arrange"....
then you can choose specific windows to run the "combine selected windows" option.
Is there a way to have this function put back on the bottom right of the window area without having to go the "Window-->Arrange" menus?
mpb
Super User mpb
I am able to invoke Combine Selected Windows from the lower right hand black triangle Arrange menu next to the checkbox in JMP 12.0.1
Hmmm... I am not seeing Select All for Arrange ... is that what you are missing?
Eric_Hill
Hey, Tim,
I'm perplexed - I don't believe we have changed anything about the Combine Selected Windows feature or the presence of the checkboxes on the status bar at the bottom of windows.  I'm attaching a screenshot of a couple report windows with the boxes checked and with the menu dropped down.
Could you maybe include a screenshot so that we can see how your windows look different?
Thanks,
Eric
tim_ka1
Hello Eric,
I was pretty sure my JMP windows did not show the checkbox option on the lower right. Now I see the checkbox. I too am perplexed.
Thank you for your help.
Tim
Eric_Hill
I do notice that if I make a window short enough, the status bar with the check box eventually goes away:
Maybe it was something like that.
But, in any case, glad you've found them!
Eric
Article Labels
