Weibayes
Do anybody knows how to perform Weibayes on Reliability data using JMP ? For example, I have only a couple of failures and given a known beta value of 0.80, how do I go about fitting the datasets to the known beta value...
mpb
Super User mpb
Re: Weibayes
In JMP: Help > Index > Type WeiBayes > Enter
Re: Weibayes
Thanks. I got the desired calculation I based on the Weibayes calculation.
Do you know how I can performed this in Script with Shift Click Function ?
mpb
Super User mpb
Re: Weibayes
You can figure it out by looking at the script generated (use Script>Save Script to Script Window). Here's what it should look like:
The inclusion of "Beta(2.3)" does the trick.
Re: Weibayes
Thanks. Everything is in ship shape, based on your input, was able to do what I need.
