klk
klk
Web Report inside project
I am having some difficulty scripting a web report inside a project.  The following code works just fine if run outside a project:
dt = Open( "$SAMPLE_DATA/Candy Bars.jmp" );
tps_html = New Web Report();
myplot = New Window( "my GB",
	Graph Builder(
		Show Control Panel( 0 ),
		Variables( X( :Sugars g ), Y( :Sodium mg ) ),
		Elements( Points( X, Y ) ),
		Local Data Filter( Add Filter( columns( :Brand ) ) )
mydist = dt << Distribution( Nominal Distribution( Column( :Name ) ) );
tps_html << Add Report( myplot, Title( "my graph builder" ), Description( "Created by unicorns" ) );
tps_html << Add Report( mydist, Title( "Distro" ), Description( "Created by unicorns" ) );
reptdir = "C:\TEMP\tps_report";
tps_html << Save( reptdir, Publish Data( 0 ) );
If I run the same code inside a project, however, it doesn't work.  The Add Report() complains:
argument is wrong type in access or evaluation of 'myplot' , myplot/*###*/
Any help is appreciated!
klk
klk
Re: Web Report inside project
I'll reply to myself here - I heard from JMP support that this is a known problem in JMP 14, and it is apparently fixed in JMP 15.
klk
klk
