wqli
Variability Summary with VB code
Hi All,
I am using the following VB.Net code to communicate with JMP automation to provide the Variability reports. But I am having problem to enable "Variability Summary" report, is there anyone able to teach me on how to enable it with automation method? Thanks.
            myJMP = New JMP.Application
            Dim JMPDoc As JMP.Document
            JMPDoc = myJMP.OpenDocument("myTest.jmp")
            Dim Vari As JMP.Variability
            Vari = JMPDoc.CreateVariabilityChart()
            Vari.VarianceComponents(JMP.varVarianceComponentConstants.varVCCrossed)
            Vari.ShowVariabilityChart(True)
            Vari.ShowBoxPlots(True)
            Vari.LaunchAddY("myY")
            Vari.LaunchAddX("myX")
            Vari.Launch()
            Vari.ShowPoints(True)
            Vari.PointsJittered(True)
            Vari.ShowCellMeans(True)
            Vari.ConnectCellMeans(True)
            Vari.ShowStdDevChart(False)
