ptolomey
Value labels are not displayed in Legend of Fit Model, Life Distribution and Fit Life by X platforms
I added value label property to Test voltage column, and expect that value labels will be displayed in graph legend.
Unfortunately value labels are not displayed in Legend of Fit Model, Life Distribution and Fit Life by X platforms.
P.S.
Test voltage column is defined as numeric continuous.
Re: Value labels are not displayed in Legend of Fit Model, Life Distribution and Fit Life by X platforms
I have replicated your findings.  I is a bug and needs to be reported to JMP Support.
     support@jmp.com
     support@jmp.com
ptolomey
Thank you for support.
