senatorx
Validate Graph output is not blank before saving
Hey,
I am creating graphs with multiple "Where" conditions that can result in no output, depending on the contents of the data file.
Where(:Column 1 == "string1" & :Column 2 == "string2" & :Column 3 == "string3")
If I then try to save a graph that is blank, the script crashes:
GraphName <<  /*###*/save picture( SaveString, png ) /*###*/;
How can I validate that the Graph contains data prior to attempting to save it?
Thanks!
pmroz
Re: Validate Graph output is not blank before saving
I would use something like:
dt << clear row states;
selected_rows = dt << get rows where(:Column 1 == "string1" &
                                     :Column 3 == "string3");
if (nrows(selected_rows) > 0,
    dt << select rows(selected_rows) << invert row selection
       << exclude << clear select;
//    Create your graph here
ms
Super User ms
Do you mean that the graph does not exist or that you have a graph but no data points (i.e. only missing values)?
Anyway, I would use a conditional statement that that is proactive, i.e. all "where" conditions that has too few data are ignored and never graphed. That's seems simpler and more efficient than to identify blank graphs in retrospect.
senatorx
I am doing this:
New Window("chart name",
CC = Control Chart(
  Chart Options...
So a new window gets created but some windows have no charts because there are no matching data points for all the where conditions.
Yeah, I think validating the data up-front before graphing is the way to go.
Thanks.
pmroz
