yaya
Community Member
VBA JMP
I am new in jmp. I want to use the function linear regression of jmp in my code vba.
I have no idea to begin.
Thank you!
Re: VBA JMP
JMP installs Automation samples that can be copy/pasted into VBA. It is in the directory specific to your version of JMP, so if you have JMP 14 it would be C:\Program Files\SAS\JMPPRO\14\Samples\Automation\Visual Basic Samples.  The Analysis.NET example will have a Bivariate example where you can see creating a Fit.  If you are trying to do this via JSL instead, the Run Command VB method can help you there.
Brian Corcoran
JMP Development
