rbeckman
V Box List and H Box List Chart Layout
Hi.  I am a new user to JSL and this forum.  I use JMP9.
I would like to create graphs that are shown horizontally by chart type, and vertically by group.  This is the default display for JMP, but I am having trouble generating a script to do this for an unspecified number of groups.
Below is a simple script to generate the charts I would like.  How can I write a script to do this for an unspecified number of groups ("age" in this case)?  Is there a more clever way to do this?
Thanks.
dt = Open( "$SAMPLE_DATA/Big Class.JMP" );
New Window( "Big Class - Oneway",
V List Box(
  H List Box(
   Bivariate( Y( :height ), X( :weight ), Where( :age == 12 ) ),
   Oneway(
    Y( :height ),
    X( :sex ),
    All Graphs( 0 ),
    Means and Std Dev( 1 ),
    Plot Quantile by Actual( 1 ),
    Line of Fit( 0 ),
    Box Plots( 1 ),
    Mean Lines( 1 ),
    Mean CI Lines( 1 ),
    Mean Diamonds( 1 ),
    Mean Error Bars( 1 ),
    Std Dev Lines( 1 ),
    X Axis Proportional( 0 ),
    Points Jittered( 1 ),
    Points Spread( 1 ),
    Grand Mean( 0 ),
    Where( :age == 12 )
  H List Box(
   Bivariate( Y( :height ), X( :weight ), Where( :age == 13 ) ),
   Oneway(
    Y( :height ),
    X( :sex ),
    All Graphs( 0 ),
    Line of Fit( 0 ),
    Box Plots( 1 ),
    Mean Lines( 1 ),
    Mean CI Lines( 1 ),
    Mean Diamonds( 1 ),
    Std Dev Lines( 1 ),
    Points Spread( 1 ),
    Grand Mean( 0 ),
    Where( :age == 13 )
  H List Box(
   Bivariate( Y( :height ), X( :weight ), Where( :age == 14 ) ),
   Oneway(
    Y( :height ),
    X( :sex ),
    All Graphs( 0 ),
    Line of Fit( 0 ),
    Box Plots( 1 ),
    Mean Lines( 1 ),
    Mean CI Lines( 1 ),
    Mean Diamonds( 1 ),
    Std Dev Lines( 1 ),
    Points Spread( 1 ),
    Grand Mean( 0 ),
    Where( :age == 14 )
  H List Box(
   Bivariate( Y( :height ), X( :weight ), Where( :age == 15 ) ),
   Oneway(
    Y( :height ),
    X( :sex ),
    All Graphs( 0 ),
    Line of Fit( 0 ),
    Box Plots( 1 ),
    Mean Lines( 1 ),
    Mean CI Lines( 1 ),
    Mean Diamonds( 1 ),
    Std Dev Lines( 1 ),
    Points Spread( 1 ),
    Grand Mean( 0 ),
    Where( :age == 15 )
  H List Box(
   Bivariate( Y( :height ), X( :weight ), Where( :age == 16 ) ),
   Oneway(
    Y( :height ),
    X( :sex ),
    All Graphs( 0 ),
    Line of Fit( 0 ),
    Box Plots( 1 ),
    Mean Lines( 1 ),
    Mean CI Lines( 1 ),
    Mean Diamonds( 1 ),
    Std Dev Lines( 1 ),
    Points Spread( 1 ),
    Grand Mean( 0 ),
    Where( :age == 16 )
  H List Box(
   Bivariate( Y( :height ), X( :weight ), Where( :age == 17 ) ),
   Oneway(
    Y( :height ),
    X( :sex ),
    All Graphs( 0 ),
    Line of Fit( 0 ),
    Box Plots( 1 ),
    Mean Lines( 1 ),
    Mean CI Lines( 1 ),
    Mean Diamonds( 1 ),
    Std Dev Lines( 1 ),
    Points Spread( 1 ),
    Grand Mean( 0 ),
    Where( :age == 17 )
ms
Super User (Alumni) ms
One approach is to use a for-loop to populate the window by re-using expressions for the graphs appending them, in this case, in pairs. See the example script below.
// list of unique values
g = Associative Array( :age << get values ) << get keys;
// Graph Expressions
bivexpr = Expr(
          Bivariate( Y( :height ), X( :weight ), Where( :age == Expr( g[i] ) ) )
owexpr = Expr(
          Oneway(
                    Y( :height ),
                    X( :sex ),
                    All Graphs( 0 ),
                    Line of Fit( 0 ),
                    Box Plots( 1 ),
                    Mean Lines( 1 ),
                    Mean CI Lines( 1 ),
                    Mean Diamonds( 1 ),
                    Std Dev Lines( 1 ),
                    Points Spread( 1 ),
                    Grand Mean( 0 ),
// Make new window
New Window( "Big Class - Oneway", vlb = V List Box() );
// Populate window iteratively
For( i = 1, i <= N Items( g ), i++,
          vlb << append(
  H List Box(
                              Eval( Eval Expr( bivexpr ) ),
                              Eval( Eval Expr( owexpr ) )
ms
bivexpr = Expr(
owexpr = Expr(
          Oneway(
                    Y( :height ),
                    X( :sex ),
                    All Graphs( 0 ),
                    Line of Fit( 0 ),
                    Box Plots( 1 ),
                    Mean Lines( 1 ),
                    Mean CI Lines( 1 ),
                    Mean Diamonds( 1 ),
                    Std Dev Lines( 1 ),
                    Points Spread( 1 ),
                    Grand Mean( 0 ),
// Make new window
          vlb << append(
  H List Box(
rbeckman
Works great.  Thanks!
