BookmarkSubscribeRSS Feed
Re: Using watches in the Debugger
shoffmeister
Community Trekker
Mar 27, 2015
I'm a bit confused by the jmp-debugger.
I would like to track a part of a matrix in my script. The matrix is stored in a variable called "output". But as the whole matrix is fairly large I want to look at the 10th column only. Somehow I am not able to do that using the "Watch"es in the debugger.
 I was expecting to see a vector in the value-column. Thanks for showing me what I am doing wrong!
markbailey
Jun 23, 2011
Solution
For your purpose of debugging, you might consider storing the portion of the matrix that you want to watch in another variable, and then setting the debugger to watch it.
You can eliminate or 'comment out' this assignment after you finish debugging this portion of the script.
markbailey
Jun 23, 2011
Solution
shoffmeister
Community Trekker
Mar 27, 2015
Sometimes it is so easy. Thanks Mark.
