BookmarkSubscribeRSS Feed
Using shape files
My goal is is to plot data on top of a map to see if GPS positions are above land or water. I can hear you think "use the background maps provided by JMP".
Unfortunately I can't find a WMS server for my area (Europe) with a map which is detailed enough and I did not succeed to load more than 10000 points on top of a WMS map.
My question: Is it possible to use a shape file as a background map and plot non related data on top of it?
XanGregg
Jun 23, 2011
Using shape files
You can turn on the World Countries Boundaries in the Background Map window. But I suppose that's not detailed enough either.
If you have your own shape files you can convert them to JMP map files (there is doc and a couple blog posts about it) or you can read the shapes yourselfs are draw them as polygons. You can even use the InPolygon function to programmatically check is a point is inside a polygon.
