fwissman
May 21, 2015
Using column data to script table edits
Hi - I apologize if this is trivial.
I have created a table SublotList from Sublot Control Data that is a single column of Sublots, they are mixed alphanumeric and not known until the original table is pulled.  I would like to use the Sublot found in the 1st row of SublotList and use it in my Select Where statement and also in the Output Table name. Then I want to step through all Sublots and quit when I use the last Sublot.  Roughly said, I'm manually entering "-A",   -A, "-L22", or -L22, etc. in many select and naming statements and would like to use these values from a separate table. I'm sure this question isn't fully formed yet, please ask questions. Thank you.
dt1<< Select Where (:SubLot == "-A");
Data Table( "Sublot Control Data" ) <<
Subset(
Output Table( "-A Sublot Control Data" ),
Selected Rows( 1 ), ,
Selected columns only( 0 ));
uday_guntupalli
Sep 15, 2014
Solution
Re: Using column data to script table edits
@fwissman ,
  Here I think this is what you are after . Let me know :
// Define Paths (edit this as needed)
SubLotControlFilePath = "C:\Users\Sublot Control Data.jmp"
SublotListFilePath = "C:\Users\Sublot List.jmp" ;
// Open Files
dt_SublotControl = Open(SubLotControlFilePath);
dt_SublotList = Open(SublotListFilePath);
// Get List of sublots
SubLotList = dt_SublotList:SubLot << Get Values;
// If you want to select all rows where sublots match sublot list
dt_SublotControl << Select Where(Contains(SubLotList,:SubLot));
// If you instead want to select rows based on subplot one after the other
for( i = 1 , i <= N Items(SubLotList) , i++,
		dt_SublotControl << Select Where(:SubLot == SubLotList[i]);
		dt_Temp = dt_SublotControl << Subset("");
		dt_Temp << set Name(Concat("Subplot-",SubLotList[i]));
Best
Uday
uday_guntupalli
Sep 15, 2014
Hello @fwissman :
     Can you upload a subset of the data table you are using ? I think the question can be addressed .
     If I understand your question correctly , you essentially want to select rows in a data table but the selection criteria is based on values from a column in the table .
     If this is correct - see if the following helps , else upload the sample data and I will try and answer your question .
     I am using the "Airline Delays" data table from the Sample Data you can find under "Help"
 // Select the data table you want to work with
dt = Current Data Table();
// Get as list the values in the column
DaysOfMonth = As List(dt:Day of Month << get Values());
// Specify the sublist in your case sublots that you want to select
DesiredDays = {1,5,7};
// Select the rows that match the criteria by wrapping in Contains
dt << Select Where(Contains(DesiredDays,:Day of Month));
Best
Uday
Best
Uday
fwissman
May 21, 2015
Hi, Uday, Here is my original table, Sublot Control Data, and my derived table, Sublot List. Please note I want to use all of the entries in Sublot List.
uday_guntupalli
Sep 15, 2014
Solution
@fwissman ,
// Open Files
Best
Uday
fwissman
May 21, 2015
Hi, Uday, Fantastic - that is exactly what I needed! Cheers! Frank
Jun 22, 2012
Here is one method that uses Joining and Subsetting with a By clause that does what is wanted
Names Default to Here(1);
dtMain=data table("Sublot Control Data");
dtList=data table("Sublot List");
dtTogether = dtMain << Join(
	With( dtList ),
	Merge Same Name Columns,
	By Matching Columns( :SubLot = :SubLot ),
	Drop multiples( 0, 0 ),
	Include Nonmatches( 0, 0 ),
	Preserve main table order( 1 )
dtTogether << delete columns("Match Flag");
dtFinal = dtTogether << Subset(
	By( :SubLot ),
	selected columns( 0 ),
	selected rows( 0 )
