DL723
Using another button instead of "Ok" - Modal windows
   Just started learning scripting so please excuse the messy or redundant coding haha.  I'm trying to combine a few things I've picked up from these forums.  Basically, give the user an option of opening a file or selecting an already open file.  I've finally figured out I needed to use a Modal window to wait for the selection is made before continuing down the script.
Is there a way to have the code continue when the selection is made? Instead of waiting for the user to press the "Ok" button?  So for my two options:
1. User opens a file --> continue when the file is opened
2. User selects an open file --> continue when the file is selected
Right now, having them press the "ok" button after the selection seems redundant.  Thanks for any help!
InputWindow = New Window( "Pick a file opening option (must be truncated)", <<modal,
V List Box(
   Text Box( "Pick a Cut and Truncated Waveform" ),
  Spacer Box( size( 1, 10 ) ),
   Button Box( "Open a file",
    path = Pick File(
	"Select Raw Waveform data",
	"", // no default directory
	{"JMP Files|jmp;jsl;jrn", "All Files|*"},
	1,
	0,
	"" // no default file
	open(path);
    	dt=current data table();
   Spacer Box( size( 10, 1 ) ),
   Button Box( "Select from a list",
   choose_data_table=function({},
list = {};
For( i = 1, i <= N Table(), i++,
	list[i] = Data Table( i ) << get name
win = New Window( "Select a data table", << Modal,
	hb = H List Box(
		Panel Box( "Choose a data table",
			dt = List Box(
				list,
				max selected( 1 ),
				chosen = Data Table( (dt << get selected)[1] );
				show (chosen);
chosen);
dt=choose_data_table();
vince_faller
Re: Using another button instead of "Ok" - Modal windows
You could just manually make the okay button and click it with btn << Click.
	<<modal,
	V List Box(
			path = Pick File(
				1,
				0,
			dt = Open( path ); //probably should do this instead of current data table()
			//dt = Current Data Table();
			btn_ok << Click;
			choose_data_table = Function( {},
				list = {};
					<<Modal,
					hb = H List Box(
							dt = List Box(
								list,
								max selected( 1 ),
								Show( chosen );
				chosen;
			dt = choose_data_table();
			btn_ok << Click;
		btn_ok = Buttonbox("OK")
But it sounds like you might not need a modal dialog.  You could just have the rest of your code execution be a function or expression and send that to each button.
domorestuff = function({},
	print(dt);
	V List Box(
			path = Pick File(
				1,
				0,
			domorestuff();
				list = {};
					<<Modal,
					hb = H List Box(
							dt = List Box(
								list,
								max selected( 1 ),
								Show( chosen );
				chosen;
			domorestuff();
Vince Faller - Predictum
vince_faller
	<<modal,
	V List Box(
			path = Pick File(
				1,
				0,
			btn_ok << Click;
				list = {};
					<<Modal,
					hb = H List Box(
							dt = List Box(
								list,
								max selected( 1 ),
								Show( chosen );
				chosen;
			btn_ok << Click;
	print(dt);
	V List Box(
			path = Pick File(
				1,
				0,
			domorestuff();
				list = {};
					<<Modal,
					hb = H List Box(
							dt = List Box(
								list,
								max selected( 1 ),
								Show( chosen );
				chosen;
			domorestuff();
David_Burnham
Modal windows are designed to force a user to click OK before execution continues.  Alternatively, you can have a non-modal window and put attach a script to either a button or a display box that allows selections.  In the example below, execution continues immediately a selection is made:
lst = {"Item 1","Item 2","Item 3","Item 4"};
nw = New Window("Selection",
	Border Box(top(20),bottom(20),left(20),right(20),
		V List Box(
			Text Box("Select an item from the list:"),
			lb = List Box(lst,<<SetMaxSelected(1),<<SetScript(doSelect()))
doSelect = Function({},{Default Local},
	lstSelected = lb << Get Selected;
	selected = lstSelected[1];
	nw << Close Window;
	show(selected);
	// continue your code here
-Dave
DL723
  Thanks for the replies.  Ah, I think everybody is correct in I didn't need it to be modal.  That was the first solution I found to getting my table to stay defined after the selection was made and the script moved past the window selection.
Either way, the self click worked for what I had written, already.  But I'll try the straight forward way of using functions.  Thanks again.
