SciOfMfg
Using a subset to select a larger dataset
I've got a large data-set of simulation data that needs to be reduced.  Table 1: Description, ID, Data1,Data2,...DataN
I double subset on Description, then on Data1.  I now know all the ID numbers I need (there are 35 unique ID's)
How can would one take the 35 unique ID's and subset Table 1 on all the rows that match the 35 unique ID's.
Re: Using a subset to select a larger dataset
You can use a Contains() function to do what you want.  Below is a very simple example.  The key will how to create a list with your 35 IDs.
idList = {"KATIE", "LILLIE", "DAVID"};
dt << select where( Contains( idList, :Name ) );
SciOfMfg
The list of ID's would come from a column in the Subset of the Subset
That makes it easy:
dtsub=data table("subsetofsubset");
idList = dtsub:ID << get values;
