BookmarkSubscribeRSS Feed
swaiper
Community Trekker
Using a delphi dll from JMP
I want to create a dll in Delphi to save differents graphs in JMP. I know the <<Save Function() work, but impossible to personalize it.
I have try this code :
dll_obj = Load DLL("C:\Users\rroustan\Desktop\Delphi\first dll\Win32\Debug\Project1.dll");
result = dll_obj << CallDLL( "AddIntegers", "n", 2 );
show(result);
dll_obj << UnLoadDLL
But in register  I saw this :
result = .;
My function in the dll just return the number 2.
How can I receive this number ?
Thanks per advance,
Sincerely
Eric_Hill
Re: Using a delphi dll from JMP
Hey, swaiper,
The first question is, is the function AddIntegers exported by your DLL, so external programs that load your DLL can call the function?  To determine this, you can run DUMPBIN.EXE, as follows, in the directory where your DLL is located:
dumpbin /exports Project1.dll
That will dump out a list of symbols that are exported by your DLL, and we can see if AddIntegers is there.
Also, what version of JMP are you using?  There is an improved DLL interface that I believe shipped in JMP 10 that may give us better diagnostic information.
Thanks,
Eric
swaiper
Community Trekker
Thank you for your answer.
I'm actually using the 12 version of JMP.
I try to create a test program in delphi and it work fine. I get the result.
I think I need to use this to have an answer by the DLL :
dll_obj <<Declare Function("name", Convention(named_argument), Alias("string"), Arg(type, "string"), Returns(type), other_named_arguments)
Eric_Hill
Hey, swaiper,
Yes, Declare Function is part of the "improved DLL interface" I mentioned.  The DLL interface that existed previously that supported only 3 fixed function signatures did *not* support returning a value, as you've figured out.  But Declare Function does allow you to declare the return type of the function and then get it back in JSL.  Something close to this should work:
dll << DeclareFunction( "AddIntegers", Convention( STDCALL ),
   Arg( Int32 ), Arg( Int32 ), Returns( Int32 ) );
That declares a function named AddIntegers that takes two integer arguments and returns an integer.  You just need to make sure that the Convention argument matches what you specified on your function declaration in Delphi.  My example assumes STDCALL, but it could be CDECL.  From what I can glean from web searches, your Delphi function declaration might look something like this:
     Function AddIntegers( i1: Integer; i2: Integer ): Integer; stdcall;
where the argument after the return type declares the calling convention.
Hope this helps.
Eric
swaiper
Community Trekker
Thank you, that's very helpful !!
swaiper
Community Trekker
Hi again,
I come back because I can't resolve my problem again with DLLs.
I have try this :
dll_obj = Load DLL("C:\Users\rroustan\Desktop\Delphi\first dll\Win32\Debug\creatorPDF.dll");
dll_obj <<DeclareFunction(
    "CreatePDF",
    Convention(STDCALL),
    Alias( "CreatePDF" ),
    Arg( AnsiString(254), "title" ),
    Arg( AnsiString(254), "path" ),
    Arg( AnsiString(254), "graphs" ),
    Arg( AnsiString(254), "fileOpen" ),
    Returns( Int32 )
rc = dll_obj << CreatePDF("title", "C:\test\", "1;2","file");
Show( result );
or try this :
result = dll_obj << CallDLL( "creatorPDF", "c", "title","C:\test\","1;2;3","file" );
But in each case, I have a big failure of JMP :
I don't understand. My DLL works fine with a delphi program. And I'm sure Delphi is using AinsiString.
Hope you can help me, again.
Thanks per advance,
Eric_Hill
Your JMP Exception could be caused by your use of the Debug build of your DLL with the Release build of JMP (which is the only build available to you).  I would suggest building the Release build of your Delphi DLL and trying that.  If that still fails, and if you are willing to do so, attach both the Debug build and the Release build of your Delphi DLL to this thread.  You may have to start a new thread to be able to attach things; I don't see an "Attach" option for my reply.
Jeff_Perkinson
When composing your response look for the "Use advanced editor" link in the upper right of the editor box. The Attach option is in the advanced editor.
-Jeff
-Jeff
