apeden
Using a Variable as a Column Identifier
How do you use a variable as a column name identifier.
I have a column in table  A which contains names in text format of columns from table B. I want to extract one of the column names from table A and use this to identify a column from column B to do a selection on.
I can extract the column identifier from column A and store this in a variable however I can t get jmp to recognise this as a column name. I have tried using
Column(column_ID_variable)
However this doesnt work as it is looking for a string instead of a variable.I have also tried using Eval on the variable but again this doesnt work.
The code line I have tried is below where the variable colvar contains the column name as a text string
tableB<<select where column(colvar)=="F");
I  would appreciate any help on this.
Thanks
Allan
pmroz
Re: Using a Variable as a Column Identifier
You need "as column", and also select where puts it's entire clause inside parentheses.
clist_dt = New Table( "Table 1",
    Add Rows( 3 ),
    New Column( "Column Names",
        Character,
        Nominal,
        Set Values( {"AAA", "BBB", "CCC"} )
data_dt = New Table( "Table 2",
    Add Rows( 6 ),
    New Column( "AAA",
        Character,
        Nominal,
        Set Values( {"A", "B", "C", "D", "E", "F"} )
    New Column( "BBB",
        Character,
        Nominal,
        Set Values( {"F", "G", "H", "I", "J", "K"} )
    New Column( "CCC",
        Character,
        Nominal,
        Set Values( {"Z", "Y", "X", "F", "E", "F"} )
for (i = 1, i <= nrows(clist_dt), i++,
    one_column = column(clist_dt, "Column Names")[i];
    data_dt << select where(as column(one_column) == "F");
    wait(3);
pmroz
    Add Rows( 3 ),
        Character,
        Nominal,
    Add Rows( 6 ),
    New Column( "AAA",
        Character,
        Nominal,
    New Column( "BBB",
        Character,
        Nominal,
    New Column( "CCC",
        Character,
        Nominal,
    wait(3);
apeden
This worked a treat.
thanks for your help.
cheers
Allan
